Fehler beim erstellen eines Backup
  • Beim Erstellen eines Backup tritt folgender Fehler auf !
    Wie kann ich das Problem lösen !!!?????
    Fehlermeldung - Details
    ZetaProducerPublishing.Runtime.Main.SendFileException
    Transfer aborted (451).
    bei ZetaProducerPublishing.Runtime.Protocols.FtpProtocol.FtpEngine.DoSendFile(SendFileInformation information) in c:\P\ukeim\zp-develop\ZetaProducerPublishing\Source\Runtime\Protocols\FtpProtocol\FtpEngine.cs:Zeile 584.
    bei ZetaProducer.RuntimeBusinessLogic.BackupAndRestore.Backup.OnlineBackupController.DoOnlineBackup(Cancelable progress, String zipFilePath) in c:\P\ukeim\zp-develop\ZetaProducerMain\Source\Core\RuntimeBusinessLogic\BackupAndRestore\Backup\OnlineBackupController.cs:Zeile 68.
    bei ZetaProducer.RuntimeBusinessLogic.BackupAndRestore.Backup.CoreBackupController.CreateBackup(CoreBackupInformation information) in c:\P\ukeim\zp-develop\ZetaProducerMain\Source\Core\RuntimeBusinessLogic\BackupAndRestore\Backup\CoreBackupController.cs:Zeile 512.
    bei ZetaProducer.Main.Backup.Create.CreateBackupSkinnedWizardForm.createBackupBackgroundWorker_DoWork(Object sender, DoWorkEventArgs e) in c:\P\ukeim\zp-develop\ZetaProducerMain\Source\Core\Main\Backup\Create\CreateBackupSkinnedWizardForm.cs:Zeile 119.
    SendFileException
    AlreadyProcessedFiles=String[]
    Length=0,
    LongLength=0,
    Rank=1,
    IsReadOnly=False,
    IsFixedSize=True,
    IsSynchronized=False
    Message="Transfer aborted (451).",
    InnerException=FtpException
    Status=ProtocolError,
    Response=FtpResponse
    Raw="451-Error during write to file\\r\\n451 Transfer aborted\\r\\n",
    Description="Transfer aborted",
    Code=451,
    Group=4
    Transfered=0,
    Transferred=0,
    RemotePath=null,
    LocalPath=null,
    ProblemType=0,
    ProtocolCode="451",
    ProtocolMessage="Transfer aborted",
    "ProtocolCode" = "451"
    "ProtocolMessage" = "Transfer aborted"
    "FtpResponse" = FtpResponse
    Code=451,
    Group=4
    "FtpStatus" = ProtocolError
    "Status" = ProtocolError
    TargetSite=RuntimeMethodInfo: olyrm,
    StackTrace=" bei Rebex.Net.Ftp.olyrm(vkvpq p0, FtpResponse p1, String p2, Int64 p3, String p4, Boolean p5, Boolean p6)\\r\\n bei iizsj.lqpyn.rjqmx(Byte[] p0, Int32 p1, Int32 p2)\\r\\n bei iizsj.lqpyn.Write(Byte[] buffer, Int32 offset, Int32 count)\\r\\n bei Rebex.Net.Ftp.bkoex(String p0, String p1, Stream p2, Int64 p3, Int64 p4, ziqoa p5)\\r\\n bei Rebex.Net.Ftp.PutFile(Stream sourceStream, String remotePath)\\r\\n bei ZetaProducerPublishing.Runtime.Protocols.FtpProtocol.FtpEngine.<>c__DisplayClass35_1.<DoSendFile>b__0() in c:\\P\\ukeim\\zp-develop\\ZetaProducerPublishing\\Source\\Runtime\\Protocols\\FtpProtocol\\FtpEngine.cs:Zeile 523.\\r\\n bei ZetaProducerPublishing.Runtime.Protocols.FtpProtocol.ActivePassiveDetectorGuard.doGuard() in c:\\P\\ukeim\\zp-develop\\ZetaProducerPublishing\\Source\\Runtime\\Protocols\\FtpProtocol\\ActivePassiveDetectorGuard.cs:Zeile 90.\\r\\n bei ZetaProducerPublishing.Runtime.Protocols.FtpProtocol.FtpEngine.guardFtpCall(FtpCall call, HandleException handleException) in c:\\P\\ukeim\\zp-develop\\ZetaProducerPublishing\\Source\\Runtime\\Protocols\\FtpProtocol\\FtpEngine.cs:Zeile 1323.\\r\\n bei ZetaProducerPublishing.Runtime.Protocols.FtpProtocol.FtpEngine.DoSendFile(SendFileInformation information) in c:\\P\\ukeim\\zp-develop\\ZetaProducerPublishing\\Source\\Runtime\\Protocols\\FtpProtocol\\FtpEngine.cs:Zeile 520.",
    Source="Rebex.Ftp",
    HResult=-2146233088
    TargetSite=RuntimeMethodInfo: DoSendFile,
    StackTrace=" bei ZetaProducerPublishing.Runtime.Protocols.FtpProtocol.FtpEngine.DoSendFile(SendFileInformation information) in c:\\P\\ukeim\\zp-develop\\ZetaProducerPublishing\\Source\\Runtime\\Protocols\\FtpProtocol\\FtpEngine.cs:Zeile 584.\\r\\n bei ZetaProducer.RuntimeBusinessLogic.BackupAndRestore.Backup.OnlineBackupController.DoOnlineBackup(Cancelable progress, String zipFilePath) in c:\\P\\ukeim\\zp-develop\\ZetaProducerMain\\Source\\Core\\RuntimeBusinessLogic\\BackupAndRestore\\Backup\\OnlineBackupController.cs:Zeile 68.\\r\\n bei ZetaProducer.RuntimeBusinessLogic.BackupAndRestore.Backup.CoreBackupController.CreateBackup(CoreBackupInformation information) in c:\\P\\ukeim\\zp-develop\\ZetaProducerMain\\Source\\Core\\RuntimeBusinessLogic\\BackupAndRestore\\Backup\\CoreBackupController.cs:Zeile 512.\\r\\n bei ZetaProducer.Main.Backup.Create.CreateBackupSkinnedWizardForm.createBackupBackgroundWorker_DoWork(Object sender, DoWorkEventArgs e) in c:\\P\\ukeim\\zp-develop\\ZetaProducerMain\\Source\\Core\\Main\\Backup\\Create\\CreateBackupSkinnedWizardForm.cs:Zeile 119.\\r\\n bei System.ComponentModel.BackgroundWorker.OnDoWork(DoWorkEventArgs e)\\r\\n bei System.ComponentModel.BackgroundWorker.WorkerThreadStart(Object argument)",
    Source="ZetaProducerPublishing",
    HResult=-2146233088
    -->Transfer aborted (451).
    Rebex.Net.FtpException
    bei ZetaProducerPublishing.Runtime.Protocols.FtpProtocol.FtpEngine.<>c__DisplayClass35_1.<DoSendFile>b__0() in c:\P\ukeim\zp-develop\ZetaProducerPublishing\Source\Runtime\Protocols\FtpProtocol\FtpEngine.cs:Zeile 523.
    bei ZetaProducerPublishing.Runtime.Protocols.FtpProtocol.ActivePassiveDetectorGuard.doGuard() in c:\P\ukeim\zp-develop\ZetaProducerPublishing\Source\Runtime\Protocols\FtpProtocol\ActivePassiveDetectorGuard.cs:Zeile 90.
    bei ZetaProducerPublishing.Runtime.Protocols.FtpProtocol.FtpEngine.guardFtpCall(FtpCall call, HandleException handleException) in c:\P\ukeim\zp-develop\ZetaProducerPublishing\Source\Runtime\Protocols\FtpProtocol\FtpEngine.cs:Zeile 1323.
    bei ZetaProducerPublishing.Runtime.Protocols.FtpProtocol.FtpEngine.DoSendFile(SendFileInformation information) in c:\P\ukeim\zp-develop\ZetaProducerPublishing\Source\Runtime\Protocols\FtpProtocol\FtpEngine.cs:Zeile 520.
    FtpException
    Code=451,
    Group=4
    Transfered=0,
    Transferred=0,
    RemotePath=null,
    LocalPath=null,
    ProblemType=0,
    ProtocolCode="451",
    Code=451,
    Group=4
    Source="Rebex.Ftp",
    HResult=-2146233088
    Ignoring inner exception because of previous OutOfMemoryException. See https://stackoverflow.com/a/25010668/107625
    der Fehler tritt beim kopieren des Backup auf den Webserver auf. Da haben Sie anscheinend die Option "Auch auf dem Webserver sichern" oder "Online Daten sichern" aktiviert.
    Der Fehler tritt auf, weil Ihre FTP-Zugangsdaten vermutlich nicht mehr korrekt sind. Möglich ist auch, dass der Speicherplatz auf dem Webserver ausgeschöpft ist. Bitte dies (auch das zu verwendende Protokoll) mit dem Provider abgleichen.
