Hallo seit einiger Zeit bricht immer wieder die Sicherung der Webseiten ab.
Wie kann der Fehler behoben werden?
Could not load Froala script 'http://localhost:9452/blazor-html-ed…-zp.pkgd.min.js'.
Error: Could not load Froala script 'http://localhost:9452/blazor-html-ed…-zp.pkgd.min.js'.
at HTMLScriptElement.onerror (https://0.0.0.1/js/froala-interop.js:208:12)
at Microsoft.JSInterop.JSObjectReferenceExtensions.InvokeVoidAsync(IJSObjectReference jsObjectReference, String identifier, CancellationToken cancellationToken, Object[] args)
at ZetaProducer.Main.PageContent.UI.Articles.ArticleDataInputs.HtmlWysiwygEditor.FroalaPreloadComponent.<>c__DisplayClass8_1.<<preloadWhenReadyAsync>b__0>d.MoveNext() in c:\P\ukeim\zp-17.2\ZetaProducerMain\Source\Core\Main\PageContent\UI\Articles\ArticleDataInputs\HtmlWysiwygEditor\FroalaPreloadComponent.razor.cs:line 62
--- End of stack trace from previous location ---
at Microsoft.AspNetCore.Components.WebView.WindowsForms.WindowsFormsDispatcher.<>c__DisplayClass5_0.<<InvokeAsync>b__0>d.MoveNext()
at Microsoft.AspNetCore.Components.WebView.WindowsForms.WindowsFormsDispatcher.InvokeAsync(Func`1 workItem)
at ZetaProducer.Main.PageContent.UI.Articles.ArticleDataInputs.HtmlWysiwygEditor.FroalaPreloadComponent.preloadWhenReadyAsync(CancellationToken cancellationToken) in c:\P\ukeim\zp-17.2\ZetaProducerMain\Source\Core\Main\PageContent\UI\Articles\ArticleDataInputs\HtmlWysiwygEditor\FroalaPreloadComponent.razor.cs:line 52
at Microsoft.AspNetCore.Components.WebView.WindowsForms.WindowsFormsDispatcher.<>c.<.cctor>b__8_0(Exception exception)
at System.RuntimeMethodHandle.InvokeMethod(ObjectHandleOnStack target, Void** arguments, ObjectHandleOnStack sig, BOOL isConstructor, ObjectHandleOnStack result)
at System.Reflection.MethodBaseInvoker.InterpretedInvoke_Method(Object obj, IntPtr* args)
at System.Reflection.MethodBaseInvoker.InvokeDirectByRefWithFewArgs(Object obj, Span`1 copyOfArgs, BindingFlags invokeAttr)
JSException
TargetSite=RuntimeMethodInfo: Throw,
Message="Could not load Froala script \\'http://localhost:9452/blazor-html-ed…27.%5C%5CnError: Could not load Froala script \\'http://localhost:9452/blazor-html-ed…C%5C%27.%5C%5Cn at HTMLScriptElement.onerror (https://0.0.0.1/js/froala-interop.js:208:12)",
Source="System.Private.CoreLib",
HResult=-2146233088,
StackTrace=" at Microsoft.JSInterop.JSObjectReferenceExtensions.InvokeVoidAsync(IJSObjectReference jsObjectReference, String identifier, CancellationToken cancellationToken, Object[] args)\\r\\n at ZetaProducer.Main.PageContent.UI.Articles.ArticleDataInputs.HtmlWysiwygEditor.FroalaPreloadComponent.<>c__DisplayClass8_1.<<preloadWhenReadyAsync>b__0>d.MoveNext() in c:\\P\\ukeim\\zp-17.2\\ZetaProducerMain\\Source\\Core\\Main\\PageContent\\UI\\Articles\\ArticleDataInputs\\HtmlWysiwygEditor\\FroalaPreloadComponent.razor.cs:line 62\\r\\n--- End of stack trace from previous location ---\\r\\n at Microsoft.AspNetCore.Components.WebView.WindowsForms.WindowsFormsDispatcher.<>c__DisplayClass5_0.<<InvokeAsync>b__0>d.MoveNext()\\r\\n--- End of stack trace from previous location ---\\r\\n at Microsoft.AspNetCore.Components.WebView.WindowsForms.WindowsFormsDispatcher.InvokeAsync(Func`1 workItem)\\r\\n at ZetaProducer.Main.PageContent.UI.Articles.ArticleDataInputs.HtmlWysiwygEditor.FroalaPreloadComponent.preloadWhenReadyAsync(CancellationToken cancellationToken) in c:\\P\\ukeim\\zp-17.2\\ZetaProducerMain\\Source\\Core\\Main\\PageContent\\UI\\Articles\\ArticleDataInputs\\HtmlWysiwygEditor\\FroalaPreloadComponent.razor.cs:line 52\\r\\n at Microsoft.AspNetCore.Components.WebView.WindowsForms.WindowsFormsDispatcher.<>c.<.cctor>b__8_0(Exception exception)\\r\\n at System.RuntimeMethodHandle.InvokeMethod(ObjectHandleOnStack target, Void** arguments, ObjectHandleOnStack sig, BOOL isConstructor, ObjectHandleOnStack result)\\r\\n at System.Reflection.MethodBaseInvoker.InterpretedInvoke_Method(Object obj, IntPtr* args)\\r\\n at System.Reflection.MethodBaseInvoker.InvokeDirectByRefWithFewArgs(Object obj, Span`1 copyOfArgs, BindingFlags invokeAttr)"
Mit den besten Grüßen JD
Titel: Zeta Producer 17
Version: 17.2.1.0
Versionsname: Business
Bitness: 64-Bit
Datum: 24.06.2026 18:45 (vor 2 Wochen)
Sprache: de
Kultur: de-DE
UI-Kultur: de-DE
Letztes Content-Update: 10.07.2026 01:14 (vor 9 Stunden)
DPI-Skalierungsfaktor: 1
Projektvorlage: Poster Responsive
Datenbank-Typ: SqlCe
Layout: Poster Responsive
Layout vorhanden: Ja
Variante: 01-technik-angepasst
Variante vorhanden: Ja
Gesamtanzahl Seiten: 29
Anzahl inaktiver Seiten: 1
Anzahl aktiver Seiten: 28
Anzahl Bilder: 66
Anzahl Dateien: 1
Zuletzt geändert: 10.07.2026 01:19 (vor 9 Stunden)
Zuletzt veröffentlicht: 10.07.2026 03:11 (vor 7 Stunden)
