• Wenn ich den FTP Server konfiguren möchte erscheint folgende Fehlermeldung:
    Access is denied (550).
    Die Firewall ist deaktiviert.
    Wo ist der Fehler!.
    Danke für ihreHilfe!
    Die gesamte Fehlermeldung lautet wie folgt:
    Rebex.Net.FtpException
    at Rebex.Net.Ftp.OM(String A, Boolean B, ZJ C, EH D, Int64 E, FtpTransferState H)
    at Rebex.Net.Ftp.JO(String A, String B, Stream C, Int64 D, Int64 E, EH H)
    at Rebex.Net.Ftp.PutFile(Stream sourceStream, String remotePath)
    at ZetaProducerPublishing.Runtime.Protocols.FtpProtocol.FtpEngine.<>c__DisplayClass4.<DoSendFile>b__3()
    at ZetaProducerPublishing.Runtime.Protocols.FtpProtocol.FtpEngine.<>c__DisplayClass20.<guardFtpCall>b__1e()
    at ZetaProducerPublishing.Runtime.Protocols.FtpProtocol.ActivePassiveDetectorGuard.doGuard()
    at ZetaProducerPublishing.Runtime.Protocols.FtpProtocol.ActivePassiveDetectorGuard..ctor(IActivePassiveDetectorHolder holder, ActivePassiveGuardDelegate guardDelegate)
    at ZetaProducerPublishing.Runtime.Protocols.FtpProtocol.FtpEngine.guardFtpCall(FtpCall call, HandleException handleException)
    at ZetaProducerPublishing.Runtime.Protocols.FtpProtocol.FtpEngine.DoSendFile(SendFileInformation information)
    at ZetaProducer.RuntimeBusinessLogic.Publishing.Testing.ConnectionTestController.doTestRunNormal(Cancelable cancelable, Boolean quickTestOnly)
    at ZetaProducer.RuntimeBusinessLogic.Publishing.Testing.ConnectionTestController.Test(Cancelable cancelable, Boolean quickTestOnly, Boolean allowThrow)
    FtpException
    Status=ProtocolError,
    Response=FtpResponse
    Raw="550 Access is denied.\\r\\n",
    Description="Access is denied.",
    Code=550,
    Group=5
    Transfered=0,
    Transferred=0,
    RemotePath=null,
    LocalPath=null,
    ProblemType=0,
    ProtocolCode="550",
    ProtocolMessage="Access is denied.",
    Message="Access is denied (550).",
    "ProtocolCode" = "550"
    "ProtocolMessage" = "Access is denied."
    "FtpResponse" = FtpResponse
    Code=550,
    Group=5
    "FtpStatus" = ProtocolError
    "Status" = ProtocolError
    TargetSite=RuntimeMethodInfo: OM,
    StackTrace=" at Rebex.Net.Ftp.OM(String A, Boolean B, ZJ C, EH D, Int64 E, FtpTransferState H)\\r\\n at Rebex.Net.Ftp.JO(String A, String B, Stream C, Int64 D, Int64 E, EH H)\\r\\n at Rebex.Net.Ftp.PutFile(Stream sourceStream, String remotePath)\\r\\n at ZetaProducerPublishing.Runtime.Protocols.FtpProtocol.FtpEngine.<>c__DisplayClass4.<DoSendFile>b__3()\\r\\n at ZetaProducerPublishing.Runtime.Protocols.FtpProtocol.FtpEngine.<>c__DisplayClass20.<guardFtpCall>b__1e()\\r\\n at ZetaProducerPublishing.Runtime.Protocols.FtpProtocol.ActivePassiveDetectorGuard.doGuard()\\r\\n at ZetaProducerPublishing.Runtime.Protocols.FtpProtocol.ActivePassiveDetectorGuard..ctor(IActivePassiveDetectorHolder holder, ActivePassiveGuardDelegate guardDelegate)\\r\\n at ZetaProducerPublishing.Runtime.Protocols.FtpProtocol.FtpEngine.guardFtpCall(FtpCall call, HandleException handleException)\\r\\n at ZetaProducerPublishing.Runtime.Protocols.FtpProtocol.FtpEngine.DoSendFile(SendFileInformation information)\\r\\n at ZetaProducer.RuntimeBusinessLogic.Publishing.Testing.ConnectionTestController.doTestRunNormal(Cancelable cancelable, Boolean quickTestOnly)\\r\\n at ZetaProducer.RuntimeBusinessLogic.Publishing.Testing.ConnectionTestController.Test(Cancelable cancelable, Boolean quickTestOnly, Boolean allowThrow)",
    Source="Rebex.Ftp",
    HResult=-2146233088
  • Hallo browe,
    versuch es doch mal mit dem "Passiv-Modus" bei den erweiterten FTP-Einstellungen, die erscheinen, wenn man auf "mehr" klickt.
    LG Sunny
    ruster.MEDIA
    Inhaber: Sonja Ruster
    Zeta 17.2.2 | Business
  • 550 bedeutet normalerweise falscher Benutzername/Kennwort oder falschen Ordner auf dem Server.
    Bentuzername/Kennwort sind OK. Ich kann jedoch im Zielordner keinen Ordner auswählen es werde keinen angezeigt im Feld Zielordner ist nur ein "/" mehr nicht.
    und wenn Sie das "/" einfach im Feld Zielordner lassen, können Sie dann anschließend veröffentlichen oder erscheint dann auch die Fehlermeldung?
  • Wenn ich das "/" weglassen kommt folgende Fehlermeldung:
    Path cannot be empty.
    Parameter name: remotePath
    Hochladen geht nicht - leider
    lg
    browe
  • Ich meinte ja auch nicht weg lassen, sondern drin lassen.
  • Sie meinen das Ordner-Icon, oder? Da müssen Sie nicht drauf klicken. Tragen Sie einfach ins Feld Zielordner den Slash ein und klicken Sie auf den Button "Weiter".
  • OK,
    besten Dank für's Testen. Dann müssten Sie uns bitte Ihr Projekt (mit korrekt konfiguriertem Username und Passwort in den FTP-Einstellungen - evtl. immer auf Weiter klicken und "trotzdem Speichern" wählen.) senden, damit wir das untersuchen können:
    • Klicken Sie auf "Aktionen"
    • Geben Sie im 1. Feld Ihre E-Mail-Adresse ein, damit wir Sie für Rückfragen kontaktieren können
    • Klicken Sie auf den Button "Senden"
    Während wir an Ihrem Projekt arbeiten, sollten Sie bei sich keine Änderungen durchführen, denn sonst müssten Sie das ggf. nochmals im von uns modifizierten Projekt durchführen.
    danke für das Projekt.
    Versuchen Sie bei Zielordner statt / bitte mal ./ einzugeben. Ich denke, das wird funktionieren.
