Problem beim Publizieren
  • Rebex.Net.FtpException
    /team/62c42aa8-2459-4a38-a432-fd2bb46ec63e.php: No such file or directory (550).
    bei Rebex.Net.Ftp.WM(String A, Boolean B, PS C, TP D, Int64 I, FtpTransferState J)
    bei Rebex.Net.Ftp.RO(String A, String B, Stream C, Int64 D, Int64 I, TP J)
    bei Rebex.Net.Ftp.PutFile(Stream sourceStream, String remotePath)
    bei ZetaProducerPublishing.Runtime.Protocols.FtpProtocol.FtpEngine.<>c__DisplayClass4.<DoSendFile>b__3()
    bei ZetaProducerPublishing.Runtime.Protocols.FtpProtocol.FtpEngine.<>c__DisplayClass2d.<guardFtpCall>b__2b()
    bei ZetaProducerPublishing.Runtime.Protocols.FtpProtocol.ActivePassiveDetectorGuard.doGuard()
    bei ZetaProducerPublishing.Runtime.Protocols.FtpProtocol.ActivePassiveDetectorGuard..ctor(IActivePassiveDetectorHolder holder, ActivePassiveGuardDelegate guardDelegate)
    bei ZetaProducerPublishing.Runtime.Protocols.FtpProtocol.FtpEngine.guardFtpCall(FtpCall call, HandleException handleException)
    bei ZetaProducerPublishing.Runtime.Protocols.FtpProtocol.FtpEngine.DoSendFile(SendFileInformation information)
    bei ZetaProducer.RuntimeBusinessLogic.Publishing.Requirements.WebServerRequirementsTestController.doTest(String serverFolder, BasePublishingEngine publishingEngine, Cancelable cancelable, PhpRequiredCapabilities reqs, WebServerAvailableCapabilities result)
    bei ZetaProducer.RuntimeBusinessLogic.Publishing.Requirements.WebServerRequirementsTestController.Test(String serverFolder, BasePublishingEngine publishingEngine, Cancelable cancelable)
    bei ZetaProducer.RuntimeBusinessLogic.Publishing.Testing.ConnectionTestController.doTestRunNormal(Cancelable cancelable, Boolean quickTestOnly)
    bei ZetaProducer.RuntimeBusinessLogic.Publishing.Testing.ConnectionTestController.Test(Cancelable cancelable, Boolean quickTestOnly, Boolean allowThrow)
    FtpException
    Status=ProtocolError,
    Response=FtpResponse
    Raw="550 /team/62c42aa8-2459-4a38-a432-fd2bb46ec63e.php: No such file or directory\\r\\n",
    Description="/team/62c42aa8-2459-4a38-a432-fd2bb46ec63e.php: No such file or directory",
    Code=550,
    Group=5
    Transfered=0,
    Transferred=0,
    RemotePath=null,
    LocalPath=null,
    ProblemType=0,
    ProtocolCode="550",
    ProtocolMessage="/team/62c42aa8-2459-4a38-a432-fd2bb46ec63e.php: No such file or directory",
    Message="/team/62c42aa8-2459-4a38-a432-fd2bb46ec63e.php: No such file or directory (550).",
    "ProtocolCode" = "550"
    "ProtocolMessage" = "/team/62c42aa8-2459-4a38-a432-fd2bb46ec63e.php: No such file or directory"
    "FtpResponse" = FtpResponse
    Code=550,
    Group=5
    "FtpStatus" = ProtocolError
    "Status" = ProtocolError
    TargetSite=RuntimeMethodInfo: WM,
    StackTrace=" bei Rebex.Net.Ftp.WM(String A, Boolean B, PS C, TP D, Int64 I, FtpTransferState J)\\r\\n bei Rebex.Net.Ftp.RO(String A, String B, Stream C, Int64 D, Int64 I, TP J)\\r\\n bei Rebex.Net.Ftp.PutFile(Stream sourceStream, String remotePath)\\r\\n bei ZetaProducerPublishing.Runtime.Protocols.FtpProtocol.FtpEngine.<>c__DisplayClass4.<DoSendFile>b__3()\\r\\n bei ZetaProducerPublishing.Runtime.Protocols.FtpProtocol.FtpEngine.<>c__DisplayClass2d.<guardFtpCall>b__2b()\\r\\n bei ZetaProducerPublishing.Runtime.Protocols.FtpProtocol.ActivePassiveDetectorGuard.doGuard()\\r\\n bei ZetaProducerPublishing.Runtime.Protocols.FtpProtocol.ActivePassiveDetectorGuard..ctor(IActivePassiveDetectorHolder holder, ActivePassiveGuardDelegate guardDelegate)\\r\\n bei ZetaProducerPublishing.Runtime.Protocols.FtpProtocol.FtpEngine.guardFtpCall(FtpCall call, HandleException handleException)\\r\\n bei ZetaProducerPublishing.Runtime.Protocols.FtpProtocol.FtpEngine.DoSendFile(SendFileInformation information)\\r\\n bei ZetaProducer.RuntimeBusinessLogic.Publishing.Requirements.WebServerRequirementsTestController.doTest(String serverFolder, BasePublishingEngine publishingEngine, Cancelable cancelable, PhpRequiredCapabilities reqs, WebServerAvailableCapabilities result)\\r\\n bei ZetaProducer.RuntimeBusinessLogic.Publishing.Requirements.WebServerRequirementsTestController.Test(String serverFolder, BasePublishingEngine publishingEngine, Cancelable cancelable)\\r\\n bei ZetaProducer.RuntimeBusinessLogic.Publishing.Testing.ConnectionTestController.doTestRunNormal(Cancelable cancelable, Boolean quickTestOnly)\\r\\n bei ZetaProducer.RuntimeBusinessLogic.Publishing.Testing.ConnectionTestController.Test(Cancelable cancelable, Boolean quickTestOnly, Boolean allowThrow)",
    Source="Rebex.Ftp",
    HResult=-2146233088
    Ich nutze den Zeta Producer 12.5.6 Business
  • hab jetzt beim Provider angefragt - dort ist alles wie es sein soll
    und es ist wohl so das ZETA beim Publizieren Test den Ordner in den publiziert werden soll löscht...
    wir haben 3mal getestet und jedesmal war der Ordner erst da und nach dem Test war er verschwunden und die Fehlermeldung kam.
    hab jetzt mal den Ordnernamen geändert in fkf und wieder das gleiche, erst ist er da, dann teste ich und dann ist er ist weg.
    /fkf/4ecade2e-1237-4dc6-b80a-2c922dfa43f3.php: No such file or directory (550). Der Inhalt kann nicht angezeigt werden, da er nicht mehr verfügbar ist.
    wenn es den Zielordner beim Verbindungstest auf dem Webserver noch nicht gibt oder dieser leer ist, dann wird der Ordner beim Test erstellt und danach wieder gelöscht. Das hat aber vermutlich nichts mit der Fehlermeldung zu tun. Versuchen Sie einfach mal die Website zu veröffentlichen (ohne Test), dann wird der Zielordner erstellt und die Daten veröffentlicht.
  • aber der Ordner ist doch da, erst nach dem Test ist er weg..und bisher gings doch immer so - erst test dann publizieren
    es kommt ja dann auch eine meldung, seite kann nicht veröffentlicht werden
    ok hab ich gemacht - ging auch, aber warum ist es auf einmal so das der Test den Ordner löscht?
    brauch ich also nicht vorher einen Ordner erstellen, den erstellt also ZETA automatisch?
  • Das der Ordner beim Test wider gelöscht wird, war schon immer so. Nur erscheint normalerweise keine Fehlermeldung. Ich vermute, dass diese aufgrund einer Serverkonfiguration erscheint.
    Wenn das Veröffentlichen funktioniert hat, dann geht nun vermutlich auch der Verbindungstest.
  • Das sieht nach 1und1 aus.
    Das Phänomen hatte ich leider auch. Unterverzeichnis erstellt, Domain darauf geroutet.
    Danach mit Zeta auf Test geklickt, danach war das UV wieder weg und ich erhielt die gleiche Fehlermeldung.
    Habe dann, da bei dem Kunden keine weiteren Projekte drauf sind, alles in die Root übertragen. Da gab es dann keine Fehlermeldung mehr.
    Is it a Bug or Feature?
    Gruss Ronny
