Probleme bei Dateiupload im Formular
    ich habe ein Formular erstellt und dort ein Dateiupload Feld eingefügt. Immer wenn man nun aber auf der Seite das Formular abschickt bekommt man nach Eingabe des Captcha folgende Fehlermeldung. Wo liegt das Problem ????
    Server Error in '/modules/10.0/Backend' Application.
    System.Web.Services.Protocols.SoapException: Server was unable to process request. ---> System.IO.FileNotFoundException: Could not find file 'D:\Data\ZetaUploaderData\V2\Anonymous\529810305'.
    at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    at System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy, Boolean useLongPath)
    at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, FileOptions options, String msgPath, Boolean bFromProxy)
    at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share)
    at ZetaUploader.ServerRuntime.DBObjects.DBUpload.getFileSize(FileSystemInfo fullPath)
    at ZetaUploader.ServerRuntime.DBObjects.DBUpload.get_IsBrowsable()
    at ZetaUploader.ServerRuntime.DBObjects.DBUpload.CoreReplacePlaceHolders(String text, Boolean expandBlocks, CultureInfo culture)
    at ZetaUploader.ServerRuntime.DBObjects.DBUpload.CoreProcessHasBlockPlaceholders(String text, Boolean has, NeedExpandDelegate needExpand)
    at ZetaUploader.ServerRuntime.DBObjects.DBBlock.CheckUploadBlocked(DBUpload info, Boolean allowHtml)
    at ZetaUploader.WebMain.WebServices.ZetaUploaderCommunication.SendFile(ZetaUploaderCommunicationClientTransferInformation information)
    --- End of inner exception stack trace ---
    Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
    Exception Details: System.Web.Services.Protocols.SoapException: System.Web.Services.Protocols.SoapException: Server was unable to process request. ---> System.IO.FileNotFoundException: Could not find file 'D:\Data\ZetaUploaderData\V2\Anonymous\529810305'.
    Source Error:
    Line 44: [System.Web.Services.Protocols.SoapDocumentMethodAttribute("http://zetauploader.zeta-software.de/webservices/SendFile", RequestNamespace="http://zetauploader.zeta-software.de/webservices/", ResponseNamespace="http://zetauploader.zeta-software.de/webservices/", Use=System.Web.Services.Description.SoapBindingUse.Literal, ParameterStyle=System.Web.Services.Protocols.SoapParameterStyle.Wrapped)] Line 45: public ZetaUploaderCommunicationClientTransferResult SendFile(ZetaUploaderCommunicationClientTransferInformation information) { Line 46: object[] results = this.Invoke("SendFile", new object[] { Line 47: information}); Line 48: return ((ZetaUploaderCommunicationClientTransferResult)(results[0]));
    Source File: c:\Windows\Microsoft.NET\Framework64\v4.0.30319\Temporary ASP.NET Files\modules_10.0_backend\8cc01fe5\28e999e6\App_WebReferences.vbvgnh16.1.cs Line: 46
    Stack Trace:
    [SoapException: System.Web.Services.Protocols.SoapException: Server was unable to process request. ---> System.IO.FileNotFoundException: Could not find file 'D:\Data\ZetaUploaderData\V2\Anonymous\529810305'. at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath) at System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy, Boolean useLongPath) at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, FileOptions options, String msgPath, Boolean bFromProxy) at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share) at ZetaUploader.ServerRuntime.DBObjects.DBUpload.getFileSize(FileSystemInfo fullPath) at ZetaUploader.ServerRuntime.DBObjects.DBUpload.get_IsBrowsable() at ZetaUploader.ServerRuntime.DBObjects.DBUpload.CoreReplacePlaceHolders(String text, Boolean expandBlocks, CultureInfo culture) at ZetaUploader.ServerRuntime.DBObjects.DBUpload.CoreProcessHasBlockPlaceholders(String text, Boolean has, NeedExpandDelegate needExpand) at ZetaUploader.ServerRuntime.DBObjects.DBUpload.CoreReplacePlaceHolders(String text, Boolean expandBlocks, CultureInfo culture) at ZetaUploader.ServerRuntime.DBObjects.DBBlock.CheckUploadBlocked(DBUpload info, Boolean allowHtml) at ZetaUploader.WebMain.WebServices.ZetaUploaderCommunication.SendFile(ZetaUploaderCommunicationClientTransferInformation information) --- End of inner exception stack trace ---] System.Web.Services.Protocols.SoapHttpClientProtocol.ReadResponse(SoapClientMessage message, WebResponse response, Stream responseStream, Boolean asyncCall) +1787189 System.Web.Services.Protocols.SoapHttpClientProtocol.Invoke(String methodName, Object[] parameters) +345 ZetaUploaderCommunication.ZetaUploaderCommunication.SendFile(ZetaUploaderCommunicationClientTransferInformation information) in c:\Windows\Microsoft.NET\Framework64\v4.0.30319\Temporary ASP.NET Files\modules_10.0_backend\8cc01fe5\28e999e6\App_WebReferences.vbvgnh16.1.cs:46 SendEMailPageBase.DoSendEMail(Encoding encoding) in d:\Websites\zeta-producer_com\modules\10.0\Backend\App_Code\SendEMailPageBase.cs:193 SendEMails_UTF_8_Index.Page_Load(Object sender, EventArgs e) in d:\Websites\zeta-producer_com\modules\10.0\Backend\SendEMails\UTF-8\Index.aspx.cs:21 System.Web.Util.CalliHelper.EventArgFunctionCaller(IntPtr fp, Object o, Object t, EventArgs e) +25 Zeta.EnterpriseLibrary.Web.Base.PageBase.OnLoad(EventArgs e) in C:\P\Zeta Enterprise Library\Source\Web\Base\PageBase.cs:44 SendEMailPageBase.OnLoad(EventArgs e) in d:\Websites\zeta-producer_com\modules\10.0\Backend\App_Code\SendEMailPageBase.cs:483 System.Web.UI.Control.LoadRecursive() +71 System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +3064
  • Hallo pierreh,
    leider haben wir bis jetzt keine Ursache festellen können, da es anscheinend nur sproadisch aufzutauchen scheint.
    Bitte nochmals testen.
    Grüße aus Göppingen
    Daniel Friedrich
  • Hallo Herr Friedrich,
    habe es nun an mehreren Rechnern probiert und das Problem taucht permanent auf. ;( Anscheinend konnten Sie aber unter pianomakler.com auch das Formular nicht erfolgreich abschicken da ich sonst ja eine Mail bekommen hätte.
    Bitte kümmern Sie sich um die Behebung des Problems denn die Seite sollte eigentlich funktionieren. Wenn ich die Uploadfelder heraus nehme funktioniert es auch nicht mehr da vom Upload anscheinend noch reste im Formularcode bleiben.
    Danke im Voraus.
    Pierre Horrolt
  • Habe scheinbar das gleiche Problem, siehe eigenen Forumsthread. Und brauche ebenso dringend eine Lösung, da mir potentielle Bewerber entegehen.
    Mit freundlichem Gruß
    Claus Zimmermann
