Fehlermeldung beim Veröffentlichen
  • was kann mein problem sein ??? wer weiss rat?
    Rebex.Net.FtpException
    Permission denied (550).
    bei Rebex.Net.Ftp.SM(String A, Boolean B, RS C, UP D, Int64 I, FtpTransferState J)
    bei Rebex.Net.Ftp.OO(String A, String B, Stream C, Int64 D, Int64 I, UP J)
    bei Rebex.Net.Ftp.PutFile(Stream sourceStream, String remotePath)
    bei ZetaProducerPublishing.Runtime.Protocols.FtpProtocol.FtpEngine.<>c__DisplayClass34_0.<DoSendFile>b__0()
    bei ZetaProducerPublishing.Runtime.Protocols.FtpProtocol.FtpEngine.<>c__DisplayClass53_0.<guardFtpCall>b__0()
    bei ZetaProducerPublishing.Runtime.Protocols.FtpProtocol.ActivePassiveDetectorGuard..ctor(IActivePassiveDetectorHolder holder, ActivePassiveGuardDelegate guardDelegate)
    bei ZetaProducerPublishing.Runtime.Protocols.FtpProtocol.FtpEngine.guardFtpCall(FtpCall call, HandleException handleException)
    bei ZetaProducerPublishing.Runtime.Protocols.FtpProtocol.FtpEngine.DoSendFile(SendFileInformation information)
    bei ZetaProducer.RuntimeBusinessLogic.Publishing.Requirements.WebServerRequirementsTestController.doTest(String serverFolder, BasePublishingEngine publishingEngine, Cancelable cancelable, PhpRequiredCapabilities reqs, WebServerAvailableCapabilities result)
    bei ZetaProducer.RuntimeBusinessLogic.Publishing.Requirements.WebServerRequirementsTestController.Test(String serverFolder, BasePublishingEngine publishingEngine, Cancelable cancelable)
    bei ZetaProducer.RuntimeBusinessLogic.Publishing.Testing.ConnectionTestController.doTestRunNormal(Cancelable cancelable, Boolean quickTestOnly)
    bei ZetaProducer.RuntimeBusinessLogic.Publishing.Testing.ConnectionTestController.Test(Cancelable cancelable, Boolean quickTestOnly, Boolean allowThrow)
    FtpException
    Status=ProtocolError,
    Response=FtpResponse
    Raw="550 Permission denied.\\r\\n",
    Description="Permission denied.",
    Code=550,
    Group=5
    Transfered=0,
    Transferred=0,
    RemotePath=null,
    LocalPath=null,
    ProblemType=0,
    ProtocolCode="550",
    ProtocolMessage="Permission denied.",
    Message="Permission denied (550).",
    "ProtocolCode" = "550"
    "ProtocolMessage" = "Permission denied."
    "FtpResponse" = FtpResponse
    Code=550,
    Group=5
    "FtpStatus" = ProtocolError
    "Status" = ProtocolError
    TargetSite=RuntimeMethodInfo: SM,
    StackTrace="bei Rebex.Net.Ftp.SM(String A, Boolean B, RS C, UP D, Int64 I, FtpTransferState J)\\r\\nbei Rebex.Net.Ftp.OO(String A, String B, Stream C, Int64 D, Int64 I, UP J)\\r\\nbei Rebex.Net.Ftp.PutFile(Stream sourceStream, String remotePath)\\r\\nbei ZetaProducerPublishing.Runtime.Protocols.FtpProtocol.FtpEngine.<>c__DisplayClass34_0.<DoSendFile>b__0()\\r\\nbei ZetaProducerPublishing.Runtime.Protocols.FtpProtocol.FtpEngine.<>c__DisplayClass53_0.<guardFtpCall>b__0()\\r\\nbei ZetaProducerPublishing.Runtime.Protocols.FtpProtocol.ActivePassiveDetectorGuard..ctor(IActivePassiveDetectorHolder holder, ActivePassiveGuardDelegate guardDelegate)\\r\\nbei ZetaProducerPublishing.Runtime.Protocols.FtpProtocol.FtpEngine.guardFtpCall(FtpCall call, HandleException handleException)\\r\\nbei ZetaProducerPublishing.Runtime.Protocols.FtpProtocol.FtpEngine.DoSendFile(SendFileInformation information)\\r\\nbei ZetaProducer.RuntimeBusinessLogic.Publishing.Requirements.WebServerRequirementsTestController.doTest(String serverFolder, BasePublishingEngine publishingEngine, Cancelable cancelable, PhpRequiredCapabilities reqs, WebServerAvailableCapabilities result)\\r\\nbei ZetaProducer.RuntimeBusinessLogic.Publishing.Requirements.WebServerRequirementsTestController.Test(String serverFolder, BasePublishingEngine publishingEngine, Cancelable cancelable)\\r\\nbei ZetaProducer.RuntimeBusinessLogic.Publishing.Testing.ConnectionTestController.doTestRunNormal(Cancelable cancelable, Boolean quickTestOnly)\\r\\nbei ZetaProducer.RuntimeBusinessLogic.Publishing.Testing.ConnectionTestController.Test(Cancelable cancelable, Boolean quickTestOnly, Boolean allowThrow)",
    Source="Rebex.Ftp",
    HResult=-2146233088
    da fehlen Ihnen vermutlich Berechtigungen. Es kann aber auch andere Ursache haben. Bitte mal folgende Punkte überprüfen:
    • Zugangsdaten sind nicht korrekt.
      Bitte Servername, Benutzername, Kennwort und Zielordner überprüfen.
    • FTP-Modus muss geändert werden.
      Standardmäßig steht der Modus auf „Automatisch“. Bitte hier mal „Passiv“ auswählen.
      Siehe auch: http://docs.zeta-producer.com/veroeffentlich…eren.html#a2147
    • Berechtigungen auf dem Webserver fehlen.
      Dies bitte prüfen und ggf. an den Provider weiterleiten.
    • Sicherheitssoftware blockiert die Verbindung.
      Bitte mal temporär Virenscanner und Firewall deaktivieren und dann nochmals testen.
    • Speicherkontingent auf dem Webserver nicht mehr ausreichend.
      Bitte überprüfen und entweder unnötige Daten vom Webserver löschen oder ein größeres Speicherpaket beim Provider ordern.
    jetzt kommt vielleicht eine banale Antwort: hatte das permission denied auch schon 5000x aaaber dann einfach ein favicon oder textdatei etc. via ftp hochladen - und schwupp wird alles erkannt. probier das doch mal :))
    LG
    Helena
    helena habs probiert hat sofoert geklappt alles bestens danke sehr
    bitte nochmal zum mitschreiben:
    Sie erhalten in Zeta Producer beim Veröffentlichen einen "Permission denied" Fehler.
    Dann veröffentlichen Sie in einem externen FTP-Programm (FileZilla o.Ä.) eine Datei auf den selben webserver und anschließend klappt das Veröffentlichen in Zeta Producer?
    Habe ich das so richtig verstanden?
  • Danke.
    Das ist ja crazy! Das werden wir mal analysieren, sollten wir jemals den "Permission Denied"-Fehler reproduzieren können.
    Ich vermute aber, dass ein Umstellen des Passiv-Modus hier aber auch zum Erfolg führen würde.
  • hallo s.seitz ,
    bei mir war Passiv eingestellt und trotzdem der fehler habe dann per FTP-Programm eine index.html als Baustellenseite hochgeladen danach ging das veröffentlichen wie von selbst dank rat von Helena
    LG schmaler73
    den PASSIV-Modus auf "PASSIV" zu schalten muss nicht zwangsweise immer die richtige Einstellung sein. Das hängt von der Anbindung ans internet ab. Es ist aber immer einen Versuch wert, den Modus mal umzustellen und zu testen, ob das Besserung bringt.
    das sehe ich ja ähnlich nen versuch ist es wert wollte ja auch nur mitteilen das es in meinem fll leider nicht daran gelegen hat
    mfg schmaler73
