Sitelock meldet eine Warnung beim e-Mail-Script
    wir haben unsere Webseite bei unserem Provider mit Sitelock geprüft und erhalten nun eine Warnmeldung bezüglich des e-Mail-Scriptes.
    Liegt das an dem Script von Zeta? Was kann man hier tun?
    Grüße Frank
    http://www.schall.de
    ZP 13.1 Business
    Synopsis: A CGI application hosted on the remote web server is potentially prone to SQL injection attack.
    Beschreibung: By sending specially crafted parameters to one or more CGI scripts hosted on the remote web server, SiteLock was able to get a very different response, which suggests that it may have been able to modify the behavior of the application and directly access the underlying database.
    An attacker may be able to exploit this issue to bypass authentication, read confidential data, modify the remote database, or even take control of the remote operating system.
    Note that this script is experimental and may be prone to false positives.
    Solution: Modify the affected CGI scripts so that they properly escape arguments.
    Technical Details:
    Using the GET HTTP method, SiteLock found that :+ The following resources may be vulnerable to blind SQL injection :+ The 'f_receiver' parameter of the //assets/php/formmailer/SendEmail.php CGI ://assets/php/formmailer/SendEmail.php?url=&f_invalidEmailMsg=keine%20g%c3%bcltige%20E-Mail&f_id=1682&f_error=http%3a%2f%2fwww.schall.de%2fsystem%2fnachricht-konnte-nicht-versendet-werden.html&f_alertPrefix=Bitte%20f%c3%bcllen%20Sie%20die%20rot%20markierten%20Felder%20aus%3a&NAME9=Textnachricht%20(optional)&NAME2=Name&NAME1=Objektbezeichnung&F9=&F8=&F7=&F6=&F1=&F2=&F3=&F4=&F5=&NAME3=Vorname&NAME4=e-Mail&NAME5=Textnachricht&NAME6=Textnachricht&NAME7=Stra%c3%9fe%2c%20Hausnummer&NAME8=Telefon%20(optional)&f_success=http%3a%2f%2fwww.schall.de%2fsystem%2fnachricht-erfolgreich-gesendet.html&f_title=Anfrage%20%c3%bcber%20www.schall.de&sc=&f_receiver=qmVf0CWGlXHMq9A%2fMiIUqQ%3d%3dzz&f_invalidEmailMsg=keine%20g%c3%bcltige%20E-Mail&f_id=1682&f_error=http%3a%2f%2fwww.schall.de%2fsystem%2fnachricht-konnte-nicht-versendet-werden.html&f_alertPrefix=Bitte%20f%c3%bcllen%20Sie%20die%20rot%20markierten%20Felder%20aus%3a&NAME9=Textnachricht%20(optional)&NAME2=Name&NAME1=Objektbezeichnung&F9=&F8=&F7=&F6=&F1=&F2=&F3=&F4=&F5=&NAME3=Vorname&NAME4=e-Mail&NAME5=Textnachricht&NAME6=Textnachricht&NAME7=Stra%c3%9fe%2c%20Hausnummer&NAME8=Telefon%20(optional)&f_success=http%3a%2f%2fwww.schall.de%2fsystem%2fnachricht-erfolgreich-gesendet.html&f_title=Anfrage%20%c3%bcber%20www.schall.de&sc=&f_receiver=qmVf0CWGlXHMq9A%2fMiIUqQ%3d%3dyy-------- output --------HTTP/1.1 302 Found-------- vs --------HTTP/1.1 200 OK------------------------+ The 'f_receiver' parameter of the /assets/php/formmailer/SendEmail.php CGI :/assets/php/formmailer/SendEmail.php?url=&f_invalidEmailMsg=keine%20g%c3%bcltige%20E-Mail&f_id=1682&f_error=http%3a%2f%2fwww.schall.de%2fsystem%2fnachricht-konnte-nicht-versendet-werden.html&f_alertPrefix=Bitte%20f%c3%bcllen%20Sie%20die%20rot%20markierten%20Felder%20aus%3a&NAME9=Textnachricht%20(optional)&NAME2=Name&NAME1=Objektbezeichnung&F9=&F8=&F7=&F6=&F1=&F2=&F3=&F4=&F5=&NAME3=Vorname&NAME4=e-Mail&NAME5=Textnachricht&NAME6=Textnachricht&NAME7=Stra%c3%9fe%2c%20Hausnummer&NAME8=Telefon%20(optional)&f_success=http%3a%2f%2fwww.schall.de%2fsystem%2fnachricht-erfolgreich-gesendet.html&f_title=Anfrage%20%c3%bcber%20www.schall.de&sc=&f_receiver=qmVf0CWGlXHMq9A%2fMiIUqQ%3d%3dzz&f_invalidEmailMsg=keine%20g%c3%bcltige%20E-Mail&f_id=1682&f_error=http%3a%2f%2fwww.schall.de%2fsystem%2fnachricht-konnte-nicht-versendet-werden.html&f_alertPrefix=Bitte%20f%c3%bcllen%20Sie%20die%20rot%20markierten%20Felder%20aus%3a&NAME9=Textnachricht%20(optional)&NAME2=Name&NAME1=Objektbezeichnung&F9=&F8=&F7=&F6=&F1=&F2=&F3=&F4=&F5=&NAME3=Vorname&NAME4=e-Mail&NAME5=Textnachricht&NAME6=Textnachricht&NAME7=Stra%c3%9fe%2c%20Hausnummer&NAME8=Telefon%20(optional)&f_success=http%3a%2f%2fwww.schall.de%2fsystem%2fnachricht-erfolgreich-gesendet.html&f_title=Anfrage%20%c3%bcber%20www.schall.de&sc=&f_receiver=qmVf0CWGlXHMq9A%2fMiIUqQ%3d%3dyy-------- output --------HTTP/1.1 302 Found-------- vs --------HTTP/1.1 200 OK------------------------
  • Die Kollegen können das später sicher noch besser (er)klären.
    Nur kurz vorneweg: Da wir keine SQL-Datenbank im Hintergrund auf dem Server haben, kann es auch keine SQL-Injection geben.
  • Sitelock und ähnliche Tools versuchen wohl SQL-Code in jede Seite der zu überprüfenden Website zu injizieren (SQL injection). Gibt die Seite einen anderen Antwortcode (HTTP-Statuscode) als 200 zurück, wird das als ein mögliches Sicherheitsproblem eingestuft.
    Laut den technischen Details wird wohl 302 zurückgegeben.
    Was hier genau zu tun ist, kann ich noch nicht sagen. Das müssen wir erst intern klären.
  • Kurz zusammengefasst. Sitelock gibt hier bezüglich unseres Mail-Skripts auf jeden Fall "falschen Alarm". Den können Sie getrost ignorieren.
    Der entscheidende Satz in der Sitelock-Fehlermeldung ist also: Note that this script is experimental and may be prone to false positives.
    Ob wir hier Zeit investieren nur um Sitelock den falschen Alarm abzugewöhnen, ist noch nicht entschieden.
